rollbar;133360 wroteWill heads off a 360 work?
RV cam; edelbrock 4bbl intake; 1406 carb & headers.
With the overbore on your 304, you MIGHT be able to use 360 heads. 2 things you'd have to watch for would be valve to cylinder wall clearance and valve to piston interference. Since the 360 head has bigger valves, the valve pockets in the pistons won't be in the right places and the intake valve may touch the cylinder wall when full open (the bigger bore may solve this). With a smaller lift cam, it may not be an issue. You don't really gain any performance, because the valve is shrouded by the cylinder wall.
On the one performance 304 I built, I went to 1.94 and 1.50 Chevy valves (stock is 1.78 and 1.40). I wish I still had those heads, hung on to them for a long time, then sold them for a song. If I still had them, I'd donate them to Ashley's project.
