rollbar
Ok guys, I'm turning this over to Ashley. Her first Jeep and she has work to do. I will help her but she will do the majority if the work.
Here she is in her Stealth mode getting her Black Ops 2.
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=41209&d=1353522272[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=41210&d=1353522282[/img]
Over view of her Jeep:
[url]http://www.youtube.com/watch?v=bwxil7Kjp7U[/url]
Carb Question:
[url]http://www.youtube.com/watch?v=YHReEx2MiJw[/url]
Thanks,
Jim
rollbar
A lot more has happened. Today, bumper install and new tank install.
[url]http://www.reno4x4.com/forum/showthread.php/65424-Ashley-s-1980-CJ7-Laredo-Build-Thread[/url]
Blown7
And so it begins..... and never ends....
rollbar
Ok went to change out Ashley's headers and also to put some umbrella seals on (couldn't get my tool to the rear of the head so we didn't do that) but while she had the first two rocker arms off she noticed one was sloppy when she went to torque it down. Come to find out she has a bent push rod. So she decided to check them all and on the passenger side there is another one and we can't get it out.
So she is going to remove the 2bbl intake and while she is at it install her 4bbl intake and carb (after she rebuilds it).
Also found a small core plug leaking so she will do that.
Long day and night so we will finish it soon.
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46807&d=1374381649[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46808&d=1374381662[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46809&d=1374381674[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46810&d=1374381685[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46811&d=1374381698[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46812&d=1374381708[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46813&d=1374381728[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46814&d=1374381738[/img]
rollbar
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46815&d=1374381748[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46816&d=1374381782[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46817&d=1374381812[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46818&d=1374381824[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46819&d=1374381835[/img]
She tried real hard to get the rod out but it felt like it was in a "Z".
rollbar
Well the beginning of open heart surgery on the Beast as Peach called it.
Ashley has decided to go w/a short block rebuild and she will learn to do the valve job. Great experience.
Look ma, no gloves. :)
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46951&d=1375067880[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46952&d=1375067894[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46953&d=1375067927[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46954&d=1375067943[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46955&d=1375067954[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46956&d=1375067964[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46957&d=1375067974[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46958&d=1375067989[/img]
rollbar
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=46959&d=1375067999[/img]
Never have done a timing set on a AMC.
Tonight, she pulles the heads off and then we will have a friend check the cyl taper since I don't know how/never done a bottom end.
rollbar
Well we stripped the motor down the rest of the way to check that push rod out and look what we found on the third rocker back from the front.
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47042&d=1375315905[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47043&d=1375315918[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47044&d=1375315932[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47045&d=1375315953[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47046&d=1375315969[/img]
rollbar
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47047&d=1375316008[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47049&d=1375316032[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47050&d=1375316052[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47051&d=1375316067[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47052&d=1375316088[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47053&d=1375316100[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47054&d=1375316112[/img]
rollbar
I think Ashley is going to buy a AMC 360 from S & J engines. Comes with a 7/100,000 mile warranty.
[url]www.sandjengines.com[/url]
Her 304 is for sale cause she wants the 360. You can still see the cross hatch on the cylinder walls.
rollbar
[url]http://www.youtube.com/watch?v=cZ7uFtjpDNU[/url]
Cam gear question.
[url]http://www.youtube.com/watch?v=UVWmuI58Cmc[/url]
The in/out of the cam is just because of the worn out timing chain and no lifters. If the lifters were there and had pressure on them, the cam would move much less. If you're using the same distributor and timing cover, those gears will work. If you're swapping distributors, then put the old gear on the distributor, or get a new matched set (Matt has them here at Bulltear).
The drive gear, fuel pump eccentric, and timing gear are held in place with 2 woodruff keys in the cam. Be sure to save them. Make sure the upper gear of the new timing set has a second oiling groove that goes all the way thru (some are blocked with casting flash). The eccentric and distributor gear will also have an oiling slot along with the key way.
A reman motor looks like the way to go.
rollbar
Thanks.
So On a re-man motor (going w/a 360) do i have to look for the fuel pump eccentric. They said at [url]www.sandjengines.com[/url] that all I need to do it the pump (which they supply a kit), timing cover, oil pan & valve covers along w/the intake. Ready to drop in 7/100,000 mile warranty.
So it I but a kit from Matt, I just bolt it on and the roll pin on the Dist.
The fuel pump eccentric is the piece between the distributor gear and the timing gear. You'll probably have to re-use the one you have. If the reman motor comes with the timing set on it, make sure you check that the oil slot is clear. Usually, when an engine eats the distributor gear, it's from a blocked oil slot and lack of oil.
rollbar
Bob look at this if you can't view the pics then go here --> Post 217 [url]http://www.reno4x4.com/forum/showthread.php/65424-Ashley-s-1980-CJ7-Laredo-Build-Thread/page9[/url]
I think I need another fuel pump eccentric.
Question.
Is this where the fuel pump rides on?
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47120&d=1375493865[/img]
If so look at this, it has a grove in it and if the new reman engine doesn't have one then I have to get one.
Is it pressed on or ?
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47121&d=1375493941[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47122&d=1375493953[/img]
[img]http://www.reno4x4.com/forum/attachment.php?attachmentid=47123&d=1375493964[/img]
rollbar
Bob, will this Fuel Eccentric work from Summit ?
[url]http://www.summitracing.com/cart/add/DCC-4120484[/url]
Thanks again for all the help,
Jim
rollbar
When I put the HBalancer back/Tcover bolts/cam bolt for the gear, can I use Blue Loc-tight ?
rollbar
Will a TF-727 Torque Converter work on a TF-999 trans ?
Thanks,
Jim
No idea on the torque converter. I'm a manual trans kind of guy.
That is what the fuel pump arm rides on, and yes, I think it's shot. The one from Summit looks right, I wasn't aware of anyone making them. Once you remove the bolt from the end of the cam, the distributor gear, eccentric, and top cam gear are just a snug fit, they should slide off with a light pull. That engine has been badly neglected, the sludge is baked on pretty thick.
rollbar
Thanks Bob.
Found out that the 727 torque converter wont fit the 999.
