yes. i meant ipm. i also used fps which would be ridiculous.
honestly, i am impressed with how this table cuts flat plate. i need to post some of my success pictures on flat plate. (need to take them too) i'm so focused on getting this rotary table working that i overlook the flat plate cutting i've done. i drew up a fixture, cut it out and welded it together yesterday and today. easy peasy. i'm getting clean cuts and sharp angles on most flat cuts.
i figured out why the tube wasn't cutting all the way around. or at least figured a way around it. my tube measures 2.55'' diameter, the drawing is 2.55'' around; but i had to enter 2.5'' in mach3 rotary screen to completely cut the tube. no problem there. i figured it out when i cut a 2.55'' tube at the 3'' setting and it cut way to far. the fix/math was easy after that.
back to my problem areas... i'm not sure the dthc is working correctly. when cutting tube the torch touches off, starts cutting and finishes one cut. the next cut the tube may wobble a little from the torch touching off. from what i read of the dthc is it should go up and down as the tube wobbles. instead it goes from long arc to scribing a line on the tube as the torch cuts out midway in the cut. i've repeated the cut and watched the z axis motor; it does not move after initial pierce adjustment. i'm also getting extreme dross on the rotary head cuts. i figure this is from slow speeds and accelerations.
in my extreme dthc test (pic below); where i'm trying to cut an oval in a fixed pipe the z axis does not move at all after the initial pierce adjustment. with my thc voltage set to 100 volts, i see the voltage climb to 128 volts with no movement of z axis. i understand i will not get an optimum cut doing this method of cut but we have a specific need to do this. the thc lite blinks and the thc on line lite is lit. all the tests for z axis reference back to home switches of which there are none.
i will call you tomorrow.
