jamscal Did it all day again today. The A would lock up, I'd swap X and A, and they would both work. At the end of the day A locked up again, I swapped cables and it followed the cables (X was now locked and A moved). Checked all the connections. It seems early today it was locked and after I checked and tightened everything in the back of the computer it worked...but I don't know if it's related I was able to cut parts intermittently. I cut small ones and baby-sat until it happened again. My thought is it's whatever drives the A axis but don't know. -James
jeepsr4ever Strange issue! Give CandCNC a shout and let them know what you found out. They may send you a new drive to install. On the replacement under warrantee they cover those parts. 903-364-2740 or 903-771-4824
jamscal Called them today after it happened again. They said it's likely a connection problem and not a problem with the drive or motor and recommended replacing the db25 cable and tightening all connections, including some of the individual screws on the driver inside the box. I did the tightening (though nothing seemed loose), scraped the pins on the connectors a bit and put it back together. I then proceeded to cut some parts with no issues. Hopefully I'm good. -James
jeepsr4ever Often times it is the most simple issue. Over the years we have found that an actual issue with the electronics has been rare and often operator, software install or PC requirements often cause issues.
jamscal Well after my last post it just went downhill, progressively acting up, to the point where the A motor is locked no matter what now. I'm going to post on their forum.
jamscal jeepsr4ever;133492 wroteOften times it is the most simple issue. Over the years we have found that an actual issue with the electronics has been rare and often operator, software install or PC requirements often cause issues. I hope it's simple but it's been the same computer and software from day one. I found this maybe similar issue and it was a bad gecko drive. Don't know if this applies to me. http://www.bulltear.com/forums/archive/index.php/t-18986.html? -James
jamscal Everything is still going fine. Wanted to update since I didn't post how the last issue was resolved. I swapped drives in the box and it cured the issue...the act of removing and retightening all the contacts probably did it. Anyway coming up on one year with the table and am going to post a one year update soon.
jamscal Some things I've done, wish I'd done, and things I've learned, general thoughts (It won't be all in one post I'm sure): I caulked between the rail and tube as pictured above. I should have also caulked between water table and tube. You can see that water has run under the water table and dripped down. (I'll probably do this the next time I clean the table) I should have done a better job painting and also painted the water table inside and out. I'm glad I got a machine torch and hand torch. Being a fab shop I of course need the hand torch and it's much easier to cut up the skeletons. I use a cheap 18" bolt cutter to cut up skeletons where possible. On good nests I can cut up a lot without breaking out the torch. Other low buck 'tool' is a 2' stick of wood, maybe 2x2". I use it to push the corner of the plates to line them up.
jamscal Other tips: I have a horizontal and vertical cut off programs (single, no offset lines the length of my travels ) I can run to help cut up the left overs....helps sometimes. I have a ton of drawings/folder now but sometimes I know I'll never use the gcode again for a nest so I put that in a folder I call NEVERAGAINNESTS and don't feel bad when I delete the contents. Still have a bunch to clean out from foolishly saving them. Also if I make a quick oneoff part I just name it delete.dxf and save it over the previous delete.dxf (and .tap) My table is full of dross again and it's past time for a cleanout....still cutting everyday. -James
jeepsr4ever Did you replace the drives with new drives or was it just moving the drive boards around? You thought it was just a connection issue with the little screws on the drives?
jamscal Just moved the drives around. It's been awhile but I think I loosed/retightened all the screws first and still had some issues, then moved them around and that was it. Also replace the db25 cable but that apparently didn't matter. -James
