jeepsr4ever;133070 wroteVerify MIC01 cable plugged into the back of the plasma cutter and two end in the correct place in the PWM box.
I'll double (triple?) check or take pics Monday.
Today's problem:
Went to the shop to fill up the water table and mess around with it.
went to zero x and y to cut a part.
Hit reference x by mistake and one motor took off and the other didn't! Hit stop but tweaked it based on measurement.
Turned everything off, pushed the gantry even (as possible) and restarted. It jogged fine but sure don't want to hit ref x again.
Also, the side that didn't take off had a set screw loose on the big gear. I tightened it. Didn't remember it being like that but could have overlooked it.
Tried to load a part that worked fine yesterday and there was an error, wouldn't run. Also the up light on the dthc was red (just twice during all this).
Not sure if any of the above is interrelated..
The 25 pin connector into the box was sagging when it happened (I had the adapter in there.) too. Replaced and tightened with replacement cord. Again not sure if related...
I'm going to loosen the bolts of the gantry, line it up and retighten.
-James
