WALT
A little every day.
WALT
[ATTACH=CONFIG]307[/ATTACH][ATTACH=CONFIG]308[/ATTACH][ATTACH=CONFIG]309[/ATTACH]
WALT
Hi gang little more done , getting nervous ,main thing now drop the fuel tank ,install electric fuel pump ,return line for fuel pressure reducer a little wiring and ? IF ANYONE CAN GIVE ME SOME ADVICE I COULD USE IT ,THANK YOU WALT.
WALT
[ATTACH=CONFIG]311[/ATTACH]
WALT
Test fit grill hit air cleaner,moved it back a little.
WALT
[ATTACH=CONFIG]312[/ATTACH]
WALT
Been sick,car up in the air,gas out,next set it up for return gas line and electric pump .
WALT
[ATTACH=CONFIG]313[/ATTACH][ATTACH=CONFIG]314[/ATTACH][ATTACH=CONFIG]315[/ATTACH]
WALT
A little more done. Pic. of new fuel tank sending unit with return line.Pic. of fuel pump and filter mounted under car. Also a pic. of tre Gearvender unit on T-10 4 speed.
WALT
Hope to get the engine started today. We just got the fuel line to complete. Going to run with supercharger dumping to the atomsphere for now. Ckeck things out for a few days then install new blow thru carb.,MSD with auto. retard,Mallery dist. with no vacuum advance. Hope we can dial it in. Any advice is more then welcome,thank you .Walt
spike
Walt
Will it not be extremely hard to tune with noise of air moving?
Goops
WALT
[ATTACH=CONFIG]316[/ATTACH]
WALT
OK,GOOD DAY,SHE RUNS MAKES ME VERRY VERRY HAPPY. RUN IT FOR A BIT SEE HOW IT GOS ,THEN INSTALL THE BLOW THRU CARB, SET BACK MSD, AND MECH ADDVANCE ONLY DISP.WE WILL GET IT ON U TUBE DOWN THE ROAD.THANK YOU BULLTEAR.
WALT
[ATTACH=CONFIG]320[/ATTACH]
WALT
750 RPMS ,MAKES ME HAPPY,WISH I HAD THE OTHER IMPELLER ,BUT I AM HAPPY.
WALT
[ATTACH=CONFIG]321[/ATTACH][ATTACH=CONFIG]322[/ATTACH]
WALT
Hi guys drove the car ,Reno said lets go ahead and install the new AED carb. Reno says this is nice then says oh no I think you got the wrong carb? Why? looking thru this cool glass window it has brass floats I think its made to be sucked thru.Dam I know I was looking at blow thru.Oh well we call AED tomorow. The brakes seemed fine on the vacuum pump.One of these days,hoping before I die.
WALT
Carp. is set up wrong. Sending it to AED and have them set ut for blow thru.
WALT
Well to bring you up to date,it will be about three weeks before getting the carb. back.Guess AED is a busy company.
WALT
[ATTACH=CONFIG]324[/ATTACH][ATTACH=CONFIG]325[/ATTACH]
