Bulltear Online Pro-parts Customers install (early AC bracket but uses the same pattern for installation)
jeepsr4ever Yes we do we are finalizing the kit and should have it for sale in our estore at the end of the week. Price is $670.
fifesjeep Very Nice.... Before I get out of the service I need to learn how to play with CNC mills and lathes... ;)
jeepsr4ever Ooops sorry I didnt see your post yes it is for sale now. Here is a pic of the York specific parts.
sethdowd Would this include replacement for ALL alternator and ac brackets (other than the AC supoort base). Also, does it come with the 7/16 bolt for alt as well as the waterpump support bolt? Sorry for so many questions...:/
jeepsr4ever This system currently only replaces the alternator bracket. The AC bracket uses a 7/16 stud on the block for the lower part of the bracket kit does not include this stud however they are cheap and easy to find.
sethdowd Just purchased one. I'm excited to get this engine install wrapped up. Which belt should I purchase for this? Also, what pulley removers do I need for the saginaw (circa 7eight) and alternator? (what size that is) Had to write out eight to get rid of double flipoff.
Mudrat Hey MC, do you support the non-AC to full AC serp kit? Running the non-AC kit now - and runs well, but want on-board air compressor. Your favorite 'Rat :-)
jeepsr4ever Absolutely Pat! You will need some spacers, a new alty bracket, a new York or Sanden clutch kit and a factory bracket for york or sanden. We will be making factory style brackets soon.
sethdowd Should I be using spacers behind my York bracket? All of the other pulleys line up fine except for the York. It's like a 1/2" too far back. There aren't instructions so I was unsure. Thanks.
Mudrat MC, any plans to have a PS bracket that moves it down or away from the Dizzy 1-2 inches? Getting those two wires through there is a bit tricky and they rub the pump housing. 'Rat
fifesjeep Mudrat;130419 wroteMC, any plans to have a PS bracket that moves it down or away from the Dizzy 1-2 inches? Getting those two wires through there is a bit tricky and they rub the pump housing. 'Rat Lets see a pic Pat?
