Brian1
Got everything wired up in my Hypertherm 1250 according to the diagram in the Candcnc manual for the 1250 model. I am still learning to use the mach interface but I am not able to fire the torch manually from the software. The DTHC online is lit green on the screen but pressing the manual fire doesnt work. What am I missing? I do hear a click coming from inside the 1250 case but get nothing else.
Your torch switch should be hooked up the the DTHC card. Can you get the unit to fire by hand? Sometimes its the plasma consumbles (torch ignitor) that fails due to consumable life and water in the line. Check for
2. Wiring on the DTHC card
Verify with the digital manual that all leads are in the right spot
Your DB9 cable is plugged in
1. On the plasma unit
You can fire the unit by hand and it does indeed make contact in the head and fire the plasma torch.
Chances are you dont have the switch wired to the card correctly.
Brian1
Yes it does fire by hand. I double checked the card when I hooked it up but I will look again. The DB9 cable is hooked up because I can hear a click inside the hypertherm case when i press the torch fire button on the screen. I am going to mess with it today and see if I can get it working
when you hear the click does the air flow start? If you have no air flow you get no fire.
Brian1
No air flows when I hear the click but the air is hooked up with pressure and when I pull the trigger on the torch manually the air comes out as well as the arc.
Check the output signals in the ports and pins menu in the config menu, output #1. It should be Port 2 Pin 1 to fire the torch.
Brian1
I will do that in a minute.
I think it has something to do with the hand torch being used and the actual Hypertherm circuitry. Right now the torch switch is wired to the board inside the plasma. I just looked at the Hypertherm manual and it said it is disabled when using the hand torch. Do I need to splice into the switch wires coming out of the hand torch and not use the connections on the board? Im thinking that is probably it.
I think you should call Hypertherm tech 1-800-643-9878 I do believe this could be an issue if the DTHC is hooked up you should not be able to fire the torch usingthe handle.
wingnut165
so what did you ever figure out? I have the same thing going on! :-|
Brian1
I fixed it by splicing into the trigger wires for the hand torch right after it enters the case. The safety built into it does not allow the trigger to be turned on from the board with the hand torch installed. I originally installed my trigger wires onto the plasma board which is why it was not firing.
Now if I could just figure out why the arc ok signal is not working/sticking I will be in good shape and finally cut some steel.
Bryan what power resistor are you using across the terminals of your current transformer? Also do you have the ark ok wires hooked from the current T-former to the right terminals on the DTHC card?
Brian1
I am using the direct connections inside the case on the board and not using a current transformer hookup.
I have narrowed it down to the plasma cutter itself because it does the same thing when it is being used as a stand-alone plasma cutter and not hooked to the CNC. I just havent had the time to sit down with it and give Hypertherm a call to troubleshoot it.
Well if you like I can send you a CT for free and get you up and running right away. They are pretty easy to install.
Brian1
Sure I will give it a try. Let me know what I need to do to get it, thanks.
Just need your shipping address again and I will get you one out.
jimcolt
Brian, Pins 12 and 14 on the rear panel connector on the powermax unit are the arc transfered signal. When the arc transfers to a piece of metal with the work clamp attached, you will see this signal go from open, to closed. You do not need a current transformer with this unit.
Jim Colt Hypertherm
I see you figured out the start input. If you use the machine torch, the start input on the rear panel connector (pins 3 and 4) is functional, short 3 to 4 and the torch will fire. If you are using a hand torch....pins 3 and 4 are inactive for safety reasons.
Ah, so your not firing but you do have everything else hooked up right? You will have to find the two leads that fire the torch that actually hook to the torch lead not the machine torch lead. Hypertherm turns off the machine torch on and off for liability however they also do not tell you how to bypass this for CNC use. There should be a plug that has many wires hooked to it (This is J19) but Hypertherm may have disable it for use with the hand torch. But there are two more leads leading to the hand torch you can use.
Brian1
No, everything is hooked up and it does fire. My problem is the arc will not stay on, it goes out after a few seconds. The arc-ok relay or whatever it is inside the plasma is bad or sticking. sometimes it works and most of the time it does not. This hapens both on the CNC and if I am just using the machine by itself.
I have seen lots of hypertherm torches misfire when the outer cap isnt all the way on or cross threaded as well. They fire then stop or just blow air. Hypertherm uses a microswitch to ensure the consumables are attached before it will fire. I can still send you that Current Transformer if you like and if you dont want to get your plasma warranteed.
Brian1
Let me mess with it a little more and if I still need the CT i will let you know, thanks.
