Installed the Volt meter gauge above the Temp gauge and using the angle like the others it fit straight above the stock temp location. If you do not use the angle set up it will hit the factory air duck and won't fit.
Bought some dumps 2-1/4" so when I want to be loud I can 🙂
Installed steering wheel and painted seat brackets and re-installed.
Adjusted the passenger door and waiting for the drivers side door striker to come in along w/the factory knobs for the twin stick.
Painted the 1/2 hard top and installed.
Installed the seat belts but I need two seat belt extensions 12-18" due to the CJ8 set up and connecting to the roll bar.
Installed NOS side mirror and I want to powder coat the side mirrors arm black.
Installed air filter system.
I still have to do the door side panels, rock guards, touch up and paint the doors as well as clean up the inside. Still little things to do.
Also need to bleed brakes, install NOS review mirror, check fuel sending gauge in tank w/a spare I have to see if the gauge registers.
I am taking the exhaust to a guy in town to do. I bought all the stuff and returned it because he can do it for the same price and probably better.
So in the mean time I did drive it around the property here and washed it 🙂
