Installed SS extended brake hose
Installed factory bump stops until I get around to newer ones
Drilling hole for manual choke installation (had one in the tool box since 2005)
Location of manual choke bracket
Manual choke bracket installed
Slide cable/sheath through the bracket and lock it down w/the lock nut
Slide choke cable through the drilled hole
Choke cable dead ended
Set desired length for sheath then cut (remove the cable from inside first)
Slide cable back through the sheath
Open the choke to set the cable, pull tight
Operate choke
Received oil back flow block off plate from my friend @ Bulltear
