willysjeepseller wroteAlright. If I run this thing till it's warm and then keep it running I can back off then tighten the stud nuts one at a time from clacking to not then 3/4 turn and i'm done?
What's up with the cam base stuff? Or is that a cold procedure?
I is confuseded?
The base circle stuff was part of a cold setting procedure for adjustable rockers.
Make sure you have an adjustable valve train. The early non-bridged rocker AMC heads ( the ones with stock studs) ARE NOT adjustable - not enough thread depth on the studs unless you have changed something else. And if you are running guide plates but have not shaved down the stud bosses to make room for them, chances are your studs are too high to crank them down enough.
If you do in fact have an adjustable stud set-up, you can run until warm, back off and then tighten till the clacking stops, and then go 1/2 to 3/4 turn more.
