mika01 wroteHow do you like the Summit K8600 cam? How is it at idle? Also what valve springs did you use?
Thanks
Mika01, The valve springs were installed by the race-shop that built the heads so I'm not sure. The stock springs were too light so they swapped them out to support a 3* valve job.
For the rest of it, I'll have to answer later ... So far it's been running on idle at the initial timing I set on the dizzy when I stuck it in there, which is? Dunno? (OK, so I goosed it a few times just to hear it roar :? ) Haven't stuck a light on it or run the Jeep more than 20-30 seconds at a time - BUT I did find a drive shaft today for the rear =D> Tomorrow I'll clean it up slap some U-joints in it and adjust the clutch :oops: Maybe on New Years I can DRIVE it :shock: That would make my YEAR!!! :!: :t:
