OK, here we go ...
How it started ... 1985 CJ-7,
White with an anemic 258 that got rebuilt .030 over, cast pistons, decked and trued the block and head. Ported and polished the head , installed new valves, stuck on a Clifford intake and headers with a Webber 38DGES carb. It ran but never left the shop. Still hasn't - it's sitting on the engine stand #-o
I sandblasted the chassis inside and out, POR-15'd it, all rust was cut out of the body (as was the figberglassed cardboard holding the driver in the Jeep :shock: ) and replaced with 16ga Galvalume. Sandblasted the under body before I fixed all the floorboards,
Bed During
Bed Afterand after hurculiner (which SUCKS)
Welded up all the soft top holes, replaced the windshield frame, rocker panels, etc ... junked the seats and bought some APC racing jobbies and installed some RCI 4-Point street belts and am working on the roll cage ... :t:
OH yeah ... While I had the body off I sent it down to the paint shop, now the White CJ is Victory red.
Rebuilt the stock axles (30/20) installed Superior one-piece axle shafts and disc brakes in back. Still got'm never used, 3.73 gears.
Got a pair of D-44's that I rebuilt, went spring over with 2.5" spring lift, spring reverse up front (and had to outboard them as well) installed a Hi-Steer, and for shits-n-grins stuck in disc brakes, Detroit lockers and 4.56's :t:
Large Jeep pic
OK, the engine ....(big pics so click if you want to see what sad shape this thing started as, click the links ... :oops:
UGLY-1
UGLY-2
After ...
Cleaning, boiling, drilling the mains,
boring .030, (cast pistons)
Truing the deck .002
Truing the heads .005
new seals, springs ... new valves Lapped with 3 angles
minor port cleaning (flashing mainly)
cross drilled and turned the crank .010 with a mirror polish
Summit K8600 Cam
Edlebrock Performer intake
Edlebrock 1407 Carb with off road needle set
Carter fuel pump
Bulltear nickle timing cover and oil pump
Bulltear underdrive pullies
Regular gas :-|
2-5/8 guages, 3"tach (65# oil pressure @1000 RPM, warm)
AGR Super II pump and gear box to help with the 35x12.5 MT/R's
The angle of the views should be oblivious :wink:
SHORT MOVIE about 1000 RPM thru the cat, no muffler ... yet
To monitor what's happening ...
And if the engine and wheels get me in - this will get me out - 12,000# with a 19,000# synthetic line :t: The fairlead just makes it go faster :wink:
What I've been working on today is having the Man-Child help with his new ride - 1999 Blazer FI 6-cyl.
HELP!!! I need a for REAL shop manual (Haynes and Chiltons are shit!!)
Oh, and this is what the Green Jeep started out as ... :!:
