Glad you found it. I couldn't see if the PS pulley is factory AMC. There are 2 flavors of PS pulleys and pumps, 74 and older has a keyed shaft and pulley and has a nut on the shaft, 75-up is just press fit. The pulleys shouldn't be too difficult to find. I have Bulltear's serpentine setup to install on my 67 Rambler with a 390. I'm using a GM type2 PS pump and a pulley from March. PS brackets are from Control Freak suspension. You might post a want ad at www.theamcforum.com
