Bigger isn't better, and a Jeep isn't a sports car. What do you use it for mostly? Mud bogs, drag racing, rock crawling? Different use means different builds for different power bands. You can't have it all, HP usually sacrifices some torque, more torque loses some HP.
You're going to be disappointed in performance with 33" tires unless you go to at least 3.73, if not 4.10 gears. I ran 4.27s in my CJ with 35s, went to 4.88s when I went to 37s.
I'd keep the compression down in the 9-9.5 range to run premium pump gas. Roller cams are nice, they do require machining the block for a cam walk plate, then you need to watch the lifter bores for diameter and uncovering of the oil slot. Higher lifts with roller lifters sometimes require bushing the lifter bores. Rollers are usually for bigger HP (higher lift and quicker valve open/close). Big oil pan is good, but don't get something so low that it gets smashed on the ground. Watch for clearance from the sump to the front diff. The jury is still out on the Sniper EFI. I haven't heard a lot about it yet. 6" rods will require machining the rod journals to 2.0" or 2.1", which is a perfect time for a stroke. It will also require custom pistons with the right compression height and pin diameter. Spend money on Aluminum heads or have the steel ones ported. AMCs like to breathe. It's money well spent.
Read this article: http://www.hotrod.com/articles/amc-brute-engines/
