Swampdog
I recently purchased the filter relocation end plate. While trying to install the oil pressure bypass spring and plunger, for some reason the plunger does not fit. I tried 2 different plungers, but both do not fit. Is there a different size plunger that this adapter uses or does it use the stock plunger. Any help would greatly be appreciated. Thank you in advance.
