I bought a cam kit off ebay that appears to be same grind as k8600 for just over $300 because of some kind of a discount that looks promising. I've been waffling a lot on build plans and considering 2 options. I have the cam kit, Edel air gap, long tube hedders, transgo 2 shift kit for the 727. I was going to start with the msd atomic efi, but after more research it looks like a quadrajet is a good option for now and do the efi later, I just happen to have a freshly rebuilt marine qjet from 1 of my boats that lost one of it's engines. Jeep comes 1st, boat later. Option 1, ( if compression is good, and I believe it is ) Cam kit, oil pump and slow down the oil to valve train, intake, carb, hedders, shift kit and whatever little problems arise, get it into the CJ have fun this fall, winter, spring and save for 383 stroker bottom end to do next year orrr... option #2 go with 343 pistons now and not do the stroker. My big question is, what is the power difference between the 2???
This is the cam kit I got, http://www.ebay.com/itm/190865000400[ATTACH=CONFIG]626[/ATTACH][ATTACH=CONFIG]627[/ATTACH][ATTACH=CONFIG]628[/ATTACH][ATTACH=CONFIG]629[/ATTACH]
