jeepsr4ever;135203 wroteThe secret to cutting diamond tread or tread plate is to use a slightly higher tip volts so your torch will never collide with the diamonds
This is what I cut at (65 amps cut speed 280, 124 volts) What would you suggest. My hyperthem has a range of 25amps to 85amps. I have no info on settings below 45amps. does anyone know of settings for cutting below 45amps?
Thanks Gary
