championc
Hi People,
I am a big fan of the AMC V8 and have a 360 in a hot rod, I swapped the old th400 as it was out of a four wheel drive with a transfer case on the back for a jaguar th400 so that I could run a jag prop with jag irs I have notice that there is a slight off set in alignment/twist of the engine and box so that the oil pan is not quite horizontal with the chassis is there some sort of conversion that will level the engine and trans to avoid oil starvation to the trans in a long corner or is this normal for the trans to be offset.
Chris.
