tufcj;135055 wroteThat left free-flow manifold will have clearance issues with the strut rod bracket. SC/Ramblers used a log style manifold. Which heads are on it?
I'm doing a tribute out of a 67 two door HT. It will be 390/5 speed on a full Control Freak suspension.
tufcj[/QUOTE
I also have the stock 1969 rectangular port heads and stock log exhaust manifolds. This engine is using the 1970 smallest combustion chamber dog-leg 291’s with screw-in studs. It appears to me that it will drop into the SC/Rambler engine bay without any issues. If not I could still use the log exhaust manifold that I have and grind in a bit of a dog-leg to almost match.
