Trs
I'm rebuilding this 360 and I'm at the point to install the crank and new bearings, The thrust plate bearing at the flywheel end is so tight it. I even put the old bearing in just to see if there was a different fit, it to is so tight the crank won't go into place. What am I doing wrong? This is my first build to so I'm on a learning curve
