Linear rails should be greased every 50 hours on the Y axis and every 200 hours on the Z axis. Ballscrew every 200 hours.
Specific grease fitting for Y axis linear way trucks
[URL]http://www.toolsource.com/lube-link-push-coupler-quick-connect-p-144782.html[/URL]
X axis rails should be wiped with cloth damp with WD40 twice weekly
Motoguy
For those of you who are Amazon/Prime addicts, like myself...
[url]https://www.amazon.com/dp/B003V5JICW/ref=cm_sw_r_sms_awd_nu2QwbY1GAKEP[/url]
tylerd
What type of grease should we be using?
Just Standard grease. Do not use any high end grease as some might have a PH that is not neutral.
tylerd
The Grease that my table came with is red, would Lucas Red & Tacky #2 work, or something more robust like either of these 2.... [url]https://www.amazon.com/Red-Line-80402-Synthetic-Grease/dp/B000CPAEJA[/url] or [url]https://www.amazon.com/DuPont-Teflon-Grease-Cartridge-14-Ounce/dp/B003UTZ4SG/ref=sr_1_5?s=automotive&ie=UTF8&qid=1504268186&sr=1-5&keywords=Red+synthetic+grease[/url]
Just want to get something close or compatible with what was already used!
Thanks!
No special grease needed.
