BodnarWelding
I have been cutting PHENOMONAL pieces lately and all of a sudden I created a job to cut out, however, it saves in Sheetcam perfectly, the simulation goes through it perfect. When I run the Post Processor, it appears to save it correctly. When I load the G code in Mach 3 it doesn't show G Code, It shows lines of stuff, but it isn't G code. I imagine I may have turned or switched something by mistake. I have also tried older files of different jobs and they all load into Mach3 the same way as the picture shows.
I have attached a picture of what it looks like. Any help is greatly appreciated!!!!!! THANKS IN ADVANCE.!!!!
Are you sure that's a .tap file?
BodnarWelding
I'm 99% sure it was. I have since been back in business cutting things out again!!! Not sure what it even turned out to be, but she's chugging along now!!!
Every now and then while cutting, seems the gantry "Jumps" or "pulses" mainly in a turn on the object being cut. I have been cutting 1/8" at 58ipm, been turning out perfect!! Very little dross on the bottom, nothing on top. Does the track on the Y axis require any type of lubricant from time to time? It appears the "drag" is coming from there.
No lube of any kind needed. Check the plug. Also check to make sure
Windows defender is turned off (real time turned off in the tools menu of Windows defender)
Remove windows security essentials.
