badaboom
Matt - Maybe you could chime in on this?
Hey I'm building a 1969 AMC 390 V8 for a Javelin SST 4 speed car.
Rectangular port heads etc .. Not trying to build a high end race engine just a good street
running AMC V8 390.
Have BW T10 and 3:54 posi configuration.
I need to understand the oil mods for the 7-8 cylinders that appear to historically run lean of oil on these motors.
I have heard of the dedicated oil line to the noted Cylinders but don't feel I need to do that.
The motor I will build will possibly hit 6000 rpm.
I have heard about using specific cam bearing with larger journal holes and using the mid plate system on the oil pump
housing and possibly better oil pump gears.
Will this be enough to cure the issues with the 7/8 cylinders?
Any help or focused advice on this would be greatly appreciated.
kinda open to cam recommendations..?
Kinds in then .480 area max lift...
bullet cams recommended
GRINDAMC 267/267H112+4
MASTERS HC 267/300 HC267/300
DUR @ .050 214/214
LIFT .480/.480
LSA 112
INT C/L 108
Any help appreciated.
