tufcj;134279 wroteIs the wear .010 or .001? If .010 then it's time for a bore anyway. I think the taper limit is .003", it's usually widest in the center of the bore.
It's under .010 but over the taper limit. A well used block that has not been rebuilt and is a good candidate for an overbore. I guess I forgot to say that I was most likely going to bore it and get new pistons. I'm looking at bumping compression ratio just a touch, with a goal of no more than 9.0:1. I want to run on regular gas.
tufcj;134279 wroteI ran the Edelbrock performer package (cam, lifters, intake) in my 360 rock crawler with Howell EFI. It passed emissions easily and had lots of torque. It didn't rev really high, ran out of steam at about 4500 rpm, but I would recommend it. The Summit 8600 cam might be a good choice also.
Thanks for that info.
I'd rather have a cam that lets me get into the 5,000-5,500 range before it's choking out. If you're dropping off with the 360 at 4500, I bet the 401 would drop off even sooner. Though that Howell is a 2bbl TBI, right? Maybe that's the limiting factor?
The Summit cam is on the list.
I've been looking a the Howards 310021-14. It's 223/223 with .480/.480 lift and 114 LSA. I've been told (by people on the internet so I'm not sure if it's true or not) that a single pattern cam will improve low end torque while maybe shaving a bit off the top end.
The Howards 3124801-11 is a bit less aggressive but still single pattern. It's 215/215 with .475/.475 lift and 111 LSA.
They also make a cam that's very close to the Edelbrock Performer. It's off by a degree on both duration numbers and LSA while the lifts are off by less than .010. It's quite a bit cheaper than the Edelbrock so I may give that a try if I want a cam in that range.
I've also looked at the Comp Cams XE256H which is 212/218 with .477/.484 lift and 110 LSA. It's a dual pattern that's only slightly more aggressive than the Edelbrock.
The Comp XE262H10 is 218/224 with .493/.500 lift and a 110 LSA. That's the same duration as the Summit 8600 with a hair more lift and 2 degrees less LSA. I remember 10 years ago hearing about Summit cams having low quality but I wonder if that was when they were switching to less zinc in the oil.
My biggest question is how these various grinds will affect emissions. I may just have to try one of the more aggressive ones and take it to be checked. If it's a problem, I can always swap in a different cam and give it another try.
