Catfish
With very little information on the web, I kinda alone in this deal.
I got a 304, was going to use the cam and AMC Performer intake on the SJ...
But since I have a spare XJ sitting here. They old hotrodder in me is taking over.
Why not a mild 304 in an XJ with a AW4 automatic, they're rated to 450lb torque.
Add in a NP231.... basically stock XJ drivetrain behind the 304.
Not planning on keeping A/C just alt and power steering on it.
I have to source eitehr shorty headers or set of stock exhaust manifolds.
i know I could build a stroker 4.6L and i have the parts to do it.
But like I say the HotRodder is taking over. I like to be different.
So opinions?
right now the 304 had a rod knocking so the crank needs turned and its got a
cam of unknown origin, but its in good shape and pistons look good so just going
to do a simple overhaul and turn the crank and maybe a 3 angle valve job.
Fueled buy a trusty Holley 4 barrel.
Should work. You will need new mounts from the frame to engine. I believe M.O.R.E. sells conversion mounts. I have an AW4 from a 2WD Grand Cherokee that I'm going to put behind a 400HP 390 in my 69 AMX. You will also need to have the AW4 flexplate match balanced to the 304 flexplate/flywheel. AMC V-8s are externally balanced, where the I-6 is internally balanced. If you use the AW4 flex plate without balancing, you will have a vibration problem. You may need the later starter, I'm not sure what the tooth count on the AW4 flexplate is.
