Okay.
After going through all the config settings and setting up X so it rebounds off the switch 2x and then semi-rapid offset .15 units off the switch to reset it/give me a start/Home0 for X.
Does that sound right? It does a double bounce off the switch before the offset?
It's working so I'm fine with that, I just don't see where I told it to do the double trigger move.
Now Y is, well, a whole nutha level...
I must need to load in an offset or something to get the gantry to travel back to the far end of the table?
Is that how you're doing it?
I have the switches set to Y Home switch in the config INPUTS and that's causing all kinds of direction/soft limit issues where the machine thinks my Y auto-square is @ Y0,0 'home' at the other end of the table, know what I mean?
C&CNC guys are telling me I need to remount my switches to the front of the gantry to properly use the Home feature, but I mounted them to the back of the uprights like I saw in the Bulltear videos/other.
Pretty sure this is the way you intended to have things mounted, but I'm missing the CommandCNC config info.
Also, on the C&CNC site there's discussion about disabling the A-axis? why would you do that?
