Dear Seller,
I just ordered a set of pistons for my stroker project. I dont live in USA so I am worried about the phone call as I don't have a USA number. I want to make sure everything is ok with the specs ordered or if you consider I should change something.
Order # 5610
The notes I added to my order were:
I want to build a 4.7L Stroker in Venezuela with following specs:
4.0 Block (53020569) bored to 3.935 (0.60)
Head 0630. (assumed 58cc Combustion Chamber, please confirm)
4.2L Crankshaft.
4.0L connecting rods.
Comp Cams 68-231-4 (Intake Duration= 250, Lobe Separation Angle=111, Advance or retard=4).
Victor Reinz 0.043" Head Gasket.
I want 0.0 deck clearance so I need the pistons to have 1.380 compression height, please confirm this, and the pin compatible with 4.0 connecting rods.
I am pointing to have 9.6 SCR@ 1600 feet. I live in a city where altitude varies from 0 to 3200 feet so I am assuming this SCR will be OK for both. No problem with premium fuel. Any recommendation here is highly appreciated as I am not an expert in engines.
Desired pistons should be (please suggest or correct anything you consider):
Custom forged +0.060" bore pistons, compression height 1.380", dish volume 20cc
