FrankNB;133801 wroteWell, after months of banging my head against the wall.. I resealed the intake, changed fuel pump and all the sensors in the fuel and exhaust systems. Last piece of the puzzle, those mofo injectors. Got new injectors from Holley and all is back to normal and had to revert to the original fuel maps and all. Figured I'd put this update in case someone gives a darn.
id be checking IAC. they hang up. next fuel map it it a one wire or heated O2? bmps help a lot. i wouldn’t chang anything else including fuel map until you figure out why it changed suddenly id go back to the 10% map if that ran.
BTW do you have spark control? speed sensor? whats the map reading did map fail;?
