tufcj;133504 wroteYou're on the right track. I'd check all the header bolts, they're notorious for coming loose. If the gaskets are bad, use Remflex gaskets, they're expensive, but I've never had one leak.
I think I found the culprit...I went to tighten all of the header bolts and some were a little loose but not really all that bad. I tightened them down and then I noticed that on the drive side there was a piece of the header flange missing. It was between two bolts where you wouldn't think it would have much of an effect but after I tightened them down it still made the popping/backfire noise. Would a big straight pipe exhaust amplify the noise when I'm driving?
