So I got the rest of the bolt out by step drilling with a drill fixture I made. The multiple drill bushings are different sizes for step drilling... from center drill thru 7/16" drill size.
Worked well....maybe if it was a seller Bulltear could offer a set someday.
Now the reason the seal started leaking is the oil slinger ring gave up the ghost being 37 years old.. my guess is it cracked form vibration and then got caught in the timing chain/gear and ripped the seal inner spring off..
So how many people have run a engine without the slinger ring and had good results on the seal not being overwhelmed with oil??
I don't feel like removing everything to install a new slinger ring (getting lazy in my old age)..so I plan on making a new slinger ring ..but it won't be the same diameter as the original ( it will be the same diameter as the seal) so I can install it thru the seal hole and have the same preload measurement for the vibration damper.
Does Bulltear or anyone sell a brand new slinger????
