tufcj;132959 wroteWelcome to Bulltear!
If the block is bored .060", the 291C heads MIGHT fit without notching the cylinders. It will depend on the cam lift. The trouble is that the valve is so close to the cylinder wall, you lose all the benefit of the bigger valve because the air doesn't flow smoothly around the valve. Put a rocker on it and turn it over by hand. If you have hydraulic lifters, be sure to allow for "pump up".
The heads are probably worth $600-700. You might be better off selling them and putting the money into a set of 304 heads using 1.94" and 1.50" valves. I had a very potent 304 motor using that setup.
Good luck with your build.
Thanks for the reply Bob! Here are the specs on the cam:
ADV Duration (INT/EXH): 280 / 290
Duration @ .050" (INT/EXH): 204 / 214
Valve Lift (INT/EXH): .448 / .472
Lobe Centerline: 110
Power Range: idle-4500
So if I can turn the motor over by hand and the valves clear, would those heads (with losing the benefit of bigger valves) perform as well as heads with the 1.94" and 1.50" valves just due to the bump in compression ratio? This is my first engine build and although I've been reading everything I can find on AMC engines for months, I'm still not sure what's best for what I'm trying to do (mostly street - light trail), higher compression ratio and less flow or vice versa?
