to make a long story short I purchased a 1973 cj5 and it is totally in pieces. I mean totally in pieces. everything is apart which is a good thing for a total restoration :wink:. seems the guy could never get around to putting it back together, sat under a tarp for over 2 years. paid $1200 which is a good thing, right? now for a great thing, I think :wink:. it came with a 304 motor which has been rebuilt, to a point. I have a short block which has been machined and assembled with crank, pistons and cam. I believe it is 40 over as this is stamped on the top of the pistons. this looks great nice and clean. I also have the stock heads which have been redone as well. so for $1200 looks like I did good, huh :wink:.
I have no experience with a amc motor but I assume it basically like most motors. so below are my questions, concerns, comments or whatever.
I have purchased a new intake a edelbrock performer. I have no idea what cam is in this motor perhaps its original spec. any way I can check? do you suggest a different cam. the jeep will primarily be a street vehicle with side trips up some trails but no heavy rock crawling.
the push rods and rocker arms are in a box that has gotten wet. the push rods are really rusted and I assume trash. i'm sure I need new ones. the rockers have a little surface rust but might be reusable once cleaned up. can I clean them and use them? best way to remove rust from them, blast? what are you thoughts on tip roller rockers?
I found the distributor in a plastic bin in 2" of water along with other things like the alternator and other various parts and brackets which are rusted to no end. my blast beater will be busy. I need to replace the distributor and was thinking of going with this http://www.ebay.com/itm/370692689100?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 any comments on that? are there any other ignition modifications I should make or consider?
I have read about making a valley oil mod for the far bearings. should I consider this?
what am I missing?
thank you in advance for comments and suggestions.
Bill
