jeepsr4ever;132439 wroteIf your not pushing 350hp you dont have oil in the pan..HA!
Oh man that wouldnt be funny.
I actually learned a leason when I was breaking in a new cam in my recently deceased 360. I started it up and heard lifter clatter. I had no oil pressure. I primed it with an old distributor and everything....
But what I didnt do was make sure the distributor was completely seated #-o
It was still meshing enough to run but wasnt engaging the pump.
From now on its check. Then triple check every detail. Because they will eat our lunch if we dont.
I think at 350 H.P. Ill be a lot happier with the new 401 over the anemic 360 it had before. Thank God all of those expensive aftermarket components are inter-changeable :occasion5:
What does it really take to squeeze out 400 ponies from these babies? I shouldnt be too far off in mods to get there... at least I hope.
I have the 670 Truck Avenger
Edelbrock Performer intake
MSD ignition
9.5:1
a little gasket matching and a 5 angle cut
with the above mentioned cam
Future plans are a 50 hp shot of juice and 2.5" duals or 3" pipes with no mufflers or cat.
What other mods can crest that number aside turbo/super/nitro?
Any one have destop dyno?
I would want to have a streetable cam without a big stall if it was imperative to swap out to get those numbers.
