djaponi3
Going through a T19 Close Ratio speed Can Anyone Provide info what it Came From ? Casting Number Side of Case 13-09-065-905 , And What I Believe is a Build Date Under the Casting Number m.5.78 ! It Has 2 SteelShift Forks in Cover with Reverse Fork Side of Case ! Other Numbers Found Stamped in Top of Case are D169 ! Just Want to Know if This was Originally in a Ford Jeep or International ! Thanks in Advance !
You're sure it's a T-19? The T-19 had a synchronized 1st gear. That leaves Jeep out, they didn't use a T-19. If it has mounting ears on the case, then it's a Ford unit. The International unit bolted on from inside the bellhousing, and didn't have the ears.
djaponi3
Definetly a T19 it has dual pto ports and top cover has T19 cast into it , mounting studs go through inside of bellhousing and no ears ! So Guess it Started life in an International ! Thanks For the Info !
