65postgs;132077 wroteI need the length of the pedestal from tip to where the bellhousing surface that mounts to the trans
I measure 1.495" at the tallest. It varies about .020" because of the rough casting.
65postgs;132077 wrotethe diameter of the pedestal
It measures .835" at the top. .920" at the bottom. The casting is tapered.
65postgs;132077 wrotethe depth of of the groove where the ball sits.
This one is approximate, I get .275". It's tough with the rough top of the casting and the curved bottom of the hole.
The ball is .625" in diameter.
Hope this helps.
