[LEFT][FONT=Verdana]Fits: 1968-74 290, 304, 343, 360, 390 and 401
Horsepower Gain Using 91 Octane Fuel: 30%@ 4-5PSI / 50% @8PSI (8PSI requires optional carb & water injection)
Supports Up To: 16psi & 800HP (with pulley change, HP carb, HP water injection, HP fuel pump & built motor
4-5PSI Kit: $4,320.00+shipping (satin, manual steering). Includes all necessary hardware, satin self-contained P-1SC centrifugal supercharger, carburetor hat, ProFlo anti-surge system, electric high pressure/high volume 650HP rated fuel pump, boost referenced fuel pressure regulator, 8-rib s/c pulley & belt, V-pulley and belt for fan, alterator and water pump, HD mounting brackets w/spring loaded tensioner
Installation Time: Approximately 1 day with normal hand tools
Warranty: 1-year limited
Availability: Approximately 2-weeks for satin or approximately 3-weeks for polished
Payment Methods: Bank to bank transfers, check or PayPal
OPTIONS:
Polished Finish +$590.00: s/c compressor, carburetor hat and brackets
Power Steering Kit +540.00: ps pump with a remote reservoir, brackets, pulleys, belt and hoses
Air Conditioning Kit +TBD: Requires Sanden A/C compressor4
150HP 750 CFM Blow Through Carb +$1,050.00: No choke, specific jets, boost ref. power valve and pressure sealed throttle shafts
Stage 1 Water Injection System + $790.00: 5 gallon reservoir, industrial grade pump, pressure senstive switch (adjustable from 0 to 9 PSI), necessary plumbling and nozzle, fully automatic operation. Suports up to 800HP
Stage 2 Water Injection System + $1050.00: Same as above except adjustalbe from 0 to 15 PSI. Supports up to 1200HP
H.O. Fuel Pump +$150: Electric EFI fuel pump supports up to 800+HP (requires 1/2” fuel line both ways after 650HP)
The Supercharger Store • 314 W. Highway 8 • Huachuca City, AZ 85616 • [/FONT][FONT=Verdana]520-456-9706 (phone) • 520-456-9868 (fax) bob@TheSuperchargerStore.com[/FONT][FONT=Verdana]www.TheSuperchargerStore.com[/FONT][/LEFT]
