Hi- I just joined this forum, looks like you have tons of good information here! I have some general compression questions and am curious to hear your thoughts and suggestions. I have searched
The backstory- I am rebuilding an AMC 360 of approximately 1984-'86 vintage for my CJ-7. I want to do a moderate performance rebuild as my plan is to eventually acquire an AMX or Javelin to swap the engine into, followed by a diesel in the CJ. That's another story for a different day. My goal is to build an engine with a power band in the idle-4000rpm (or so) range, with 350 hp and 400 ft lbs torque at the flywheel. (I know, the jeep doesn't need that much power, but I'm an engineer and the challenge is part of the fun) This is a fairly low budget rebuild.
The engine will be bored .030 over. The ports have been gasket matched, rough spots removed, nothing too extreme. A 3 angle valve job has been done. I will run an Edelbrock Performer intake and long tube in frame headers leading to dual Flowmaster 40 series mufflers. Fuel delivery is via an early '90s GM TBI system with a hybrid TFI/MSD 6 ignition. The ECM also controls the spark (no knock sensor, though). Cam will be the Summit K8600 or possibly the Comp Cams 268H grind. Manual transmission.
Does my target power seem reasonable? From my research it seems legitimate, but I don't know that I can do it without upping the compression a bit. If I can accomplish it at stock compression that would be great, but I am assuming I can't.
My main question- what would you think is the highest dynamic compression ratio can I run on 87-89 octane 10% ethanol pump gas? I have read on some forums (perhaps this one, I can't remember exactly) that 9.25 to 9.5:1 static CR is about the limit. This wouldn't normally be an issue, except as you probably know there is a dearth of off-the-shelf higher compression pistons available for the AMC 360. At the moment, I can't budget the custom forged pistons that Bulltear offers. That pretty much means that the only low budget option I have is to do the cast "343 pistons in a 360" trick. I ran some calculations (http://www.kb-silvolite.com/calc.php?action=comp) and if I could get a hold of the 2V 343 pistons (14 cc dish volume) it would put me in the right range. (with of course, all the caveats to that trick like clearancing piston skirts for the crank counterweights, balancing the rotating assembly, etc) I can't find those pistons, however there is an eBay seller selling the 4V 343 pistons. With those (no dish, 4 valve reliefs) I would be looking at about 10.25:1 static CR. Dynamic CR is somewhere in the mid 7's:1.
With a computer controlled spark, longer duration cam, and 10% ethanol gas in this area, would I be able to run a 10.25:1 static compression without knocking, preferably on 87 or 89 octane? I know it is probably on the hairy edge, but just curious to get some opinions. If so, with that and the other mods mentioned above, should I be able to hit my torque/hp targets?
Thanks for your assistance and any information you can provide!
