These are quick settings for those who loose a PC and need to reboot. These may not be yoor machine's specific motor tuning values. You should call in or check your machines data plate (If applicable)
X,Y,A axis settings
Steps Per 2405.75 (alternative 2345.76 depending on gear set)
Velocity 800 (This is your rapid speed)
Accel 40
Z axis settings
Steps Per 12000
Velocity 90 (This is your rapid speed)
Accel 15
A axis must be slaved to X axis and must be moving in the opposite direction under ports and pins motor outputs you must have A axis either checked green or red X in the DIR/LOW ACTIVE collumn and X axis set with a green check or red X BUT THE TWO CANNOT BE THE SAME. ONE GREEN CHECK ONE RED X. If they are kept the same you will damage your gantry.
Jakey
What are the Z values for the Proton Z upgrade, i see the motor is now smaller and i assume the steps per and vel numbers will be different?
Thanks
10130 Steps per, Velocity 120 (to start with) and accel 30-50
