3/10/12. Got the engine back from the machine shop. The block is a 68/69 390 I've had in the shed for close to 10 years, it was bored but never finish honed. Crank and rods were originally from my AMX (that block was really messed up when I got the AMX). Pistons are OEM .030 cast. Heads are 291C's that I traded for some 090's.
The red in the valleys and on the heads is a product called "Glyptal", basically a red high temp enamel paint. It's supposed to make the oil pass back to the pan faster. The block already was drilled for the valley line, so I'll use it. It also got main studs, but I didn't take pics.
Heads are 291C, they shaved .005" to assure they are flat, 3 angle valve job, hardened seats, positive seals, new guides. Guides have been cut for lift of up to .550". Valves are factory, springs and retainers are Crower. Studs are ARP SBC. I'll be using Crane roller rockers.
Crank had to be turned .020/.020. Rods were resized with ARP bolts. See how little was drilled from the harmonic and flywheel to balance it.
I'll have this manifold powder coated before installation. Two 400 CFM throttle bodies going on it.
