SSS
I recently put a bigger hypertherm unit on my machine. While jogging it around and testing it out the table shut down. Now when I restart the machine, on the front of the CandCNC panel I have a constant pulse stream to the Y axis (according to LED indictor). Charge pump light will not come on. Error panel in Mach says, External Estop requested.(I dont have an external estop on the machine) Mach will not let me take it out of reset. I have checked, rechecked, and triple checked all my setting to verify that they are correct. Verified that all the cables are pluged into the correct spots.
I also have remote computer access to the Computer hooked up to the machine if you want access to see if you can diagnose the problem. If so I'll PM the info to you
Any help would be greatly appreciated.
Thanks,
Chris
I see you found the support line.
Did you reload your software? Did you check the plasma setup topic area?
SSS
Yeah.. after talking to Tom I reloaded the software for the Parallel port card. I still have llights out on the Raw import bits so I think I have a bad parrallel port card. I have order a new one. Hopefully this fixes it
Thanks
Are you up and running? We are curious here. :D :)
