montelibre
I have been put the Bulltear custom pistons into the block, but all the pistons are a different deck (about +0.09 mm, +0.20 mm, +0.36mm, +0.15mm,+ 0,20mm, +0,15mm).
What is happening?
I wanted to have zero deck.
I bought a MLS victor reinz head gasket, however at this moment I don't know if is better to put a Perma-Torque head gasket.
I am thinking to lower the top of the pistons for to obtain zero deck and install the MLS head gasket.
Did you get reconditioned rods for this build? When they recondition them the end up shorter than stock, they basically take a little off the big end between the cap and rod, then put the two back together and line bore the bearing journal to make it round again, My guess is that you have different length rods or your deck is really out of whack
