http://home.roadrunner.com/john.strenk/Gauge%20web%20page/basic_troubleshooting_for_cj_gau.htm#Warning
http://home.roadrunner.com/john.strenk/Gauge%20web%20page/CJSpeedometerGaugeQuickTest.htm
I have power to the RED lead "I" terminal. NO power to "S" or "A".
If it doesn't light at all then you probably have a problem with the points on the current regulator or a broken connection.
Question, what are the Points & current regulator, where are they and what do they look like?
Where can I buy a set?
Thanks,
Jim
One more question.
What if I installed a after market fuel gauge and new tank sender set up. Would it be hard to hook up? Would I use the power from the fuel gauge now (red) and then I would have to run a wire from the sender or use existing. I'm thinking existing.
