Jeep won't stay running.
Sorry for all the questions etc.
I also hooked up a test light to the power steering bracket and tested it and it works from there so my grounding should be ok.
I ran a wire to the + side of the coil from the battery and as long as I keep the key on it would try to fire but when I let the key go it would not stay running. The starter was keeping it firing/spinning over etc.
Without the jumper wire to the + side of the coil it would just go VROOM and die.
Below wiring and routing for the Jeep.
NOTICE-the brown wire trying in w/the red/white and crimped then going to the solenoid, NOT SURE what that's about.
NOTICE-I know I don't need it but I left the old harness incase I wanted to install the I-6 again. Also Notice I just cut the ends off the solenoid and added crimped on ends but left them in their position. Also notice the distributor I hooked that one up and left off the one in the harness as you see at the top. MAYBE I need to use that one ?? But I don't think it has the green wire.
Any help would be appreciated even if I have to gut the wires and start over, but I would know where to start.
Solenoid - Note: the blue wire runs to the fire wall block plug.
See the Red/White wire in the loom
Solenoid Red/white wire tied into brown w/green lettering wire running to drivers side compartment
Brown wire w/green lettering @ drivers side block tied into thicker red/white wire. Blue wire from solenoid into block. Notice the blue wire from the other side of the solenoid.
Red thick wire from fire wall block and blue wire to module
Red thick wire tied into the red/white one
