ironman_gq;129581 wroteI had the same problem but I ended up breaking one and bending 3 others 2 at almost a 90. No bent valves, no witness marks on the pistons, no bad rockers or stuck lifters. Im pretty sure the valves stuck in their guides. maybe a little condensation or moisture got in there and the valve stem stuck to the guide enough to bend the rods.
By the way, Did you determine what caused your issue and what did you do to rectify it?
