Agree that the comp cam mentioned would be way to big and it is a chevy grind not optimized for the bigger Chrysler lifter- check comp cams cam listing pdf
The Engle mentioned is also a much bigger cam (209@.050) than stock- you will lose torque in a stock motor
Engle measures @.008- He may have the lobe mentioned below- ask him for the "Dick Jones Motorhome special"
this is a max lobe for the .904 lifter shorter duration but about the same lift as the Engle
Look for something like this
@.008 @.006 @.050 lobe 1.5 1.6 1.7
H440D64307 256° 260 202° .307" .461" .491" .522"
Comp has no AMC/ Chrysler .904 diameter lifter grinds grinds shorter than 280
Crane has some here
http://www.cranecams.com/uploads/lobe/masterlisting.pdf
H2 and H3 series page 6
examples @.004 so appears longer than cam above but is actually a little smaller
1.5 1.6 1.7
H-202/2880 274 @.0040 .431 .461 .490 202 @.050 28880 /lobelift
I've run the Jones cam with that CR with excellent results
Crower has a good selection as does Engle
