donwag
Where is the best place to get a new 401 flywheel? I have looked at the Bulltear Products site and it looks like they do not carry them.
Thanks.
fifesjeep
There are various vendors on the net... You just have to hunt for them. OR.... you could check out the FSJ sites and the baby Jeep sites and poke around....
eBay has some listed for $135-154 for a standard flywheel, up to $412 for a McLeod billet unit. With anything non-OEM, I'd have it balanced before installation.
donwag
Thanks. I think Omix-Ada makes all the stock replacements. Several racing applications are available, but this is a daily driver.
MC is/was an Omix-Ada distributor. You might PM him (jeepsr4ever) to see if he can get one for you.
JERSEYJOE
Getting it balanced means getting the entire rotating assembly balanced not just the flywheel
BREK
Not necessarily Joe, he could have it match balanced to a stock flywheel if he has one.
matty 401
what if he is going from an auto to a stick can they match the flex plate to the flywheel as far as balancing goes
The budget flywheels can be garbage. We had one spin a ring gear even though it was welded and the weight was off. If you get one of the $150 and less flywheels do yourself a favor and get it balanced.
fifesjeep
I purchased a 360 flywheel back in the day and the machine shop had to drill a lot of material out of it... I noticed that on the back side there was a decent sized pocket/void... lol
Henry Lavrenz
I bought one from Jegs, about 14 months ago - it is a hays steel billet. About $340 bucks. At that time they had none in stock and a guy named Jim ( from Hays) called me and said they are doing a run of ten of them at that time. Hankrod
Blown7
Mondello here. Just remember Mondello flywheels require that you make a spacer plate between the engine and trans.
Magical_Merlin
Jegs has them for around $80.
