rollbar Here is what I just found but its NOT for a CJ 🙁 OK guys time to order 🙂 http://www.autotrucktoys.com/jeep/Mo...-PRD20931.aspx Write up: http://www.jeepforum.com/forum/f9/en...install-928591 Post 12 will give you a idea/picture. http://www.jeepforum.com/forum/f96/anyone-have-block-heater-installed-933951 http://www.fordtractorpart.com/tractor-tank-type-heaters-270-ctg.html Battery and Pad Heaters: http://www.padheaters.com/battery_heater.html http://www.jcwhitney.com/blanket-style-battery-warmer/p2006128.jcwx?skuId=206279&TID=231000000&zmam=15972153&zmas=21&zmac=123&zmap=541427 Mudrat sent me this: Sorry don't have a source for block heaters. JC Whitney is showing a couple oil pan heaters though ... http://www.jcwhitney.com/oil-pan-hea...lterid=c1648j1 http://www.jcwhitney.com/magnet-moun...lterid=c1648j1 And Titan offers some size/capacity options: http://www.padheaters.com
rollbar Does anyone know the size of the freeze plug for a 1986 AMC 258 and for a 1977 (I think) AMC 360? I am also going to check into the lower rad hose install, from what I hear it is easier and works the same. I have a magnetic one like this some one gave me, haven't tried it yet but from what I hear, they don't work so good: http://www.jcwhitney.com/magnet-mount-engine-block-heater/p2000836.jcwx?TID=8014524FT2&zmam=15972153&zmas=21&zmac=165&zmap=10836G NAPA: 258 CID ('86) http://www.napaonline.com/Search/Results.aspx?Ntt=engine%20block%20heater&N=599001+101986+50038+2038003+4038012+5999999&Ntk=Keyword NAPA: 360 CID '78 http://www.napaonline.com/Search/Results.aspx?Ntt=engine%20block%20heater&Ntk=Keyword&N=599001+101978+50038+2038032 Lower radiator hose, same link as above for the 360:
rollbar Starting at post 57, I installed the engine block heater, w/pics etc. Post from my CJ8 Build http://www.bulltear.com/forums/showthread.php?17201-CJ8-to-M170-Build&p=129803#post129803 Thanks, Jim
