BRAD ARTHUR;128791 wrotedo you know if the mr. gasket 12 s pump has a fuel pressure cutt out switch in it (build a certain pressure then shut off) seems like it would if it delivers only 4-7 psi? aand has any one had any experience with these pumps?
When I had an eddy carb on the old 304 I ran the Mr. Gasket 12S electric fuel pump.... and It ran non-stop.... I also had a return line to the tank. Hell, I removed it and it sat in my garage on the shelf for over a year and when I hooked it back up to see if it would work... It DID!!! Needless to say, I was impressed. If I remember right it was pushing around 6.0psi (according to the gauge I was using). IMO, it did what it was supposed to and for that I can't take nothing from it.
