82waggy360
Are there two different gasket designs when using a oil pump mid plate or do you use two normal oil pump gaskets on either side of it? It looks like it should have a different design/cutout gasket between the plate and oil filter adapter. Mine came with three gaskets of all the same design. Thanks for any help.
Same gasket for the bottom. The shiney gasket is the thin .007"
82waggy360
Thanks for the reply, I just got this thing all put back together and didnt want to smoke the engine over one little gasket.
